Fuel Pump Question
Old Jul 5, 2012 | 11:16 AM
pcarollo's Avatar
Default Fuel Pump Question
Ok so my '94 Z28 with 30k on my new engine has this issue, only happens when I drive around a lot, freeway or in town, and when it is hot outside. I'm talking temps around 100 and humid. Monday I drove it about 100 miles, hot outside, came off the freeway and headed home obviously at slower speeds. I could hear the fuel pump kick in and shortly thereafter the car died. If I tried to start it the fuel pump would kick in and it would not start, like it's sucking air. You could smell the gas fumes in the car and I took the gas cap off and got a loud suction noise. I waited about 10 minutes and it started right up. This is the second time in a week it has done this, pretty much the same scenario. It is my daily driver and takes me to work about 40 miles per day. I have no problems with this otherwise.
Suggestions?
Old Jul 5, 2012 | 11:22 AM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
could be the wiring getting too hot or the pump itself. is it the original pump? or was it upgraded or swapped out with the new motor?
Old Jul 5, 2012 | 12:04 PM
Old Jul 5, 2012 | 12:37 PM
H2C's Avatar
H2C
Def sounds evap. Scroll down and read my thrashes titled fuel pump issues for some tips
Old Jul 5, 2012 | 01:37 PM
pcarollo's Avatar
Thanks for the info, and yes I believe it is the original fuel pump. I've had the car 2 years and have not replaced it in that time period. Just the engine, water pump, radiator, hoses and such to get the 3 year unlimited mileage warranty.
pcarollo
Sep 30, 2014 10:08 PM
krazymonkeys
May 16, 2012 12:13 AM
rachel11
Apr 3, 2012 07:26 AM
1997Z28
May 25, 2010 10:28 PM
camarofreak1990
Jun 26, 2009 12:48 AM
