Fuel Pump Inertia Switch
Old Jul 19, 2008 | 09:04 AM
Dementia's Avatar
Default Fuel Pump Inertia Switch
Is there one a 98 Camaro. I've searched google but it seems to be a debate on whether or not GM used these at all. Thanks
Old Jul 19, 2008 | 12:41 PM
Default RE: Fuel Pump Inertia Switch
Not on Camaro.
Old Jul 19, 2008 | 02:48 PM
That would be a redundant safety feature anyway, because the fuel pump power supply is controlled by the oil pressure switch once the engine is running. In a crash, the engine generally kills, dropping the oil pressure down to zero, and shuts off the fuel pump.
Old Jul 20, 2008 | 08:17 AM
Dementia's Avatar
Thanks guys. I found the problem. I bought the car after it had been wrecked and the fuel pump would not turn on. The covers under the hood for the fuses and relays were missing. I figured it out. My a/c and fuel pump relays were also missing. Put one in and it fired right up. Its a 43k 98 and has sat for 4 yrs but doesnt smoke or tick. Got lucky there, but the clutch disc was stuck to the flywheel. Its free now but it chatters like hell. Ah well you win some and lose some.
mitchman
Jun 10, 2013 04:45 PM
camaroneedsrepair
May 30, 2008 02:48 AM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
