Which Fuel Pump to buy
$168? Might as well go with the best and save some money while your at it.
93-97 LT1 Fbody Racetronix High Performance In Tank Fuel Pump Assembly | WS6store.com
Thanks.
I am not familiar with how the check valve works. I assume there is a check valve within the pump. In the link you posted it says this pump works with the existing check valve in the bucket.
My pump has plenty of pressure and always runs. When shutting car off, the pressure drops. It is not injectors or regulator, it is check valve. I assumed it was in the pump, but now confused.
Is the check valve in buck just to keep bucket full and there is another internal to the pump?
Thanks again
Thanks again
i used a aftermarket pump (walboro) that doesnt use the bucket. i installed it in the old bucket and plastic welded it back together. seems to be working. if or when i do it again i would use a stock oem that includes the bucket. the check valve in the bucket is just for the bucket. keeps the fuel from running out as fast as its goin in. check valve in pump is separate valve.
LS1 Camaro Trans AM (Trap Door Fuel Pump Install *1993-1998*) - YouTube
Hope it helps
johnson3034
05-25-2007 09:35 PM
