Fuel line upgrade questions?
If anyone has upgraded there fuel lines on a z28 I'm looking for information. I need to know part numbers and the parts that were used so I can upgrade mine. Thank you...
My fuel line is kinked, I do not know how to get kinked only thing I can think of is previous owner. But I'm just trying to replace them. I have seen a tread a few months ago but can't find it now so I'm just asking
you can re route it to behind the brake booster. getting the end to reseal is a pita and usually ends in replacing with rubber/synthetic line. it changes to steel down under below the driver side door jam. have a look at this thread https://camaroforums.com/forum/93-02...el-line-76894/
Dorman makes replacement nylon line. The line itself is not very expensive. The tool to crimp a quick connect into the line, however, is not cheap. Though you can get nylon line with the quick connect already on it too.
