fuel level sender
Old Aug 27, 2013 | 11:24 AM
saltflat's Avatar
Default fuel level sender
hi, my 02 3.8 camaro conv. has a fuel level gauge problem. i did a trap door exposure of the fuel pump assm .does anyone have schematic of the wiring to the pump assm. there are two plugs one three wire and one four wire .im trying to locate the level sender wires. thanks for any help.
Old Aug 27, 2013 | 11:53 AM
see if the wires are the same color as the 93-97 4th Gen LT1 F-body Tech Articles
you know the 4th gen fuel gauge is prone to running out of fuel at 1/8 to 1/4 tank at the gauge. my first 4th gen ran out a little over 1/8th tank. this one goes till it just gets to e. also 1/2 tank on the gauge is around 1/4 in reality.
Old Aug 27, 2013 | 06:26 PM
Massey's Avatar
The small plug is for the evap system sensor the large plug is the feed to the fuel pump and the sender in the tank. Sorry I dont know what color is what off the top of my head. The sender is nothing more than a variable resistor that can wear out over time.
Massey
Old Aug 31, 2013 | 04:02 PM
saltflat's Avatar
the fuel level sender is wired to the ppl and blk/wht wires of the 4 wire plug. the pump wires are gr and blk.thanks for the help.
evilbeef54
Jul 27, 2008 09:47 PM
Mizz_Camaro
82-92 V6 Tech
Aug 16, 2007 10:21 PM
1995Camaro
May 23, 2007 08:58 PM
worknon10s
May 15, 2007 10:41 AM
microkid
Jan 6, 2007 11:10 PM
