Fuel Gauge
Old Aug 17, 2009 | 07:32 PM
wolf_t's Avatar
Default Fuel Gauge
Yesterday I filled the car to full. Before that the meter was showing 1/4 .
But after pumping 6 gallons the tank was full, the meters shows full.
Where can I start to fix this problem ?
Thanks ...
Camaro V6 2000
Old Aug 18, 2009 | 12:59 AM
did u pump till it stopped on its own or just put 6 gals in and u stopped it?
Old Aug 18, 2009 | 09:46 AM
95slvrZ28's Avatar
You can fix the problem by redesigning your fuel tank or by applying a nonlinear voltage modifier to the electronic control that tells the PCM how much fuel there is...seriously though, it's a known issue with the cars. Is the tank showing that it's FULL (needle past the F) or is it just close to full? My gas gauge is pretty screwed up too, the top of the tank goes by really really slow on the gauge, and then it just plummets...
Old Aug 18, 2009 | 11:53 AM
shawnathan's Avatar
mine go's really quick then at like a 1/4 it will stay there for like 5 days worth of driving lol it just takes some gettin used to
Old Aug 18, 2009 | 01:12 PM
MisterCynical's Avatar
Sounds like its doing the exact opposite of what every other Camaro does.
Old Aug 18, 2009 | 04:33 PM
josh95camaro's Avatar
Mine stays at full FOREVER then all of a sudden it seems like its gone... ii dont go by the fuel gauge any more, just by miles. I usually get 275 miles out of a full tank
94Zman
May 30, 2013 06:54 PM
Jr. Mechanic
Mar 2, 2010 02:36 PM
tylerparson
Aug 19, 2008 08:02 AM
vzfox
Nov 10, 2007 10:05 PM
BlueKitsune
Oct 5, 2007 07:54 PM
