ford fuel pump in a chevy...
Old Nov 2, 2010 | 07:15 PM
BasicConcepts's Avatar
Technical User
Default ford fuel pump in a chevy...
i knew it was a bad idea but it was free
this ford fuel pump is not good enough or something i hear it kick on but it takes like 3 min of cranking to start the car then the car runs like sht so im just gunna breakdown and get a brand new pump but im deff not dropping the tank so i had a couple questions about the the hatch method first whats the best tool to cut this with second what do you guys do about the lines they run across the front of the tank and theres no disconnect there can i just cut them at the sending unit and then clamp it all back together with high pressure fuel line
Old Nov 3, 2010 | 11:05 AM
H2C's Avatar
H2C
Chainsaw dude, gut that ***** open
and do not disconect those lines by cutting, reach up and follow them two or three inches abnd youll see the disconect
Old Nov 3, 2010 | 01:33 PM
Technical User
lol i think the chainsaw might be a little to much but im pretty sure the only disconnects are all the way at the front driverside corner of the tank
Old Nov 3, 2010 | 02:36 PM
H2C's Avatar
H2C
The wire doesnt that i found, and yes if you reach under the front drivers side where the lines go, just follow them under there, then you will find the disconnect. and also yeah use a sawzall to barely open it up the use yellow handle snips, or straight snips as some call them lol.
Old Nov 3, 2010 | 06:17 PM
Technical User
well i just had the tank out 4 days ago and the disconnects are basically where the fuel filter is i remember saying (and notice i say alot when working on this car) what the fck was chevy thinking when they built this one
Old Nov 3, 2010 | 06:25 PM
Buffalo02Z28's Avatar
Its all good, I put Motorcraft oil in my car one time. Its actually pretty good stuff.
Old Nov 3, 2010 | 06:35 PM
Technical User
lol ya this pump was free but now im starting to think my fpr may be going bad i dont know i hooked up a fuel pressure gauge and it was getting about 16lbs during the crank then ill stop and the pump will run again and bring the gauge up to 19lbs then as soon as the pump stops i instantly lose pressure all tho the car does run better now than it did yesterday i could actually drive it... but anyways if i pull the vac line off the fpr the gauge just chills at 16lbs (while the cars running) it should go up to like 46 i think maybe even higher cuz this is off a V8 explorer
BlwnProStreetLuvr
Sep 28, 2010 10:44 PM
Dount
VS
Nov 6, 2009 11:37 PM
nickalvrz
Sep 24, 2007 05:46 AM
