first brake change on camaro
Old Mar 3, 2011 | 12:24 PM
dogdog130's Avatar
Default first brake change on camaro
i have drove a jeep cherokee and this first brake change on my camaro so i took tire off but to undo the caliper it a weird bolt what do i need to use to get it free or is there a other way
Old Mar 3, 2011 | 01:11 PM
torque_is_good's Avatar
nothing weird about it at all, I believe it's a 9mm hex key or socket. it's pretty common among a lot of cars
Old Mar 3, 2011 | 01:27 PM
BasicConcepts's Avatar
Technical User
actually i think its a 8mm hex
Old Mar 3, 2011 | 03:52 PM
DarkKnight's Avatar
GTO Killer
LimeKnight
its only one bolt... how much easier do you want it to be? that the bolt off, slade caliper off rotor, swap pads,,,, thats an easy brake job man,,,
Old Mar 3, 2011 | 04:41 PM
MelloYello's Avatar
1 bolt? u shure on that? smells like calipers are held on by two bolts to me
Old Mar 3, 2011 | 05:01 PM
DarkKnight's Avatar
GTO Killer
LimeKnight
i dont take the calipers apart to change pads on these cars, just detach the caliper as a whole
Old Mar 3, 2011 | 07:10 PM
REN's Avatar
REN
One bolt will undo the caliper but mine was thread locked, had to use a breaker bar to turn it. Also if you take the rotor brackets off- use loctite, wish I knew that before...
Old Mar 4, 2011 | 10:43 AM
dogdog130's Avatar
not a 8mm trying ( now
Old Mar 4, 2011 | 11:11 AM
Chevy101's Avatar
Mine was either a 12 or 13mm I forget exactly
Old Mar 5, 2011 | 09:59 AM
dogdog130's Avatar
3/8 at advanced auto it works great did it in 45 min
