Fender Question 93-98 bumber swap?
Can i keep the same fenders if i switch my front end out for a 98.......
and why do i have to change the hood. it looks the same as the 98.......
What parts from a 95 can i keep.....
What kind of car do you have? Is that T/A in your avatar what you are talking bout? Camaros had the same bodies from 93-97, then changed in 98-02. Same with the Firebirds.
ORIGINAL: Alih
you have to change the hood because it is shaped different it matches up with the lights, the fenders should be ok you might have to adjust them though
You have to change the fenders--the whole front clip, really. The headlamps would not fit right with LT1 car fenders still in place.
Just an FYI...
