failed emmissions
Old Sep 27, 2008 | 11:20 PM
stealthy95z's Avatar
Default failed emmissions
they say that the egr works fine but its got alot of unburned gas. exhaust is magnaflow (unsure of exactly what it has but it does have a cat. kid I bought the car from says it has a lunati street cam, and it does have sort of a lopey idle so it may or may not, I dont know for sure.
I found it interesting that the emmissions guy said the egr works fine, because just after the valve the line is cut off and crimped. lol
no check engine light, and it seems to run good, but at 130,000 I guess it could use new plugs and wires. any other suggestions?
Old Sep 28, 2008 | 01:30 AM
BeraniHull's Avatar
Default RE: failed emmissions
New Cat?
Old Sep 29, 2008 | 05:48 PM
ABKorrupt's Avatar
check fuel injectors, not sure but does the street cam need bigger injectors? mine needed 2 to be replaced and still need to get the others cleaned...
Old Sep 29, 2008 | 06:22 PM
Your mechanic probably just looked at the scanner, and as long as the EGR pintle was able to move, it saw no problem. However, you should take down the EGR, clean the passages and put back all the wires and hoses where they belong. If the EGR is blocked/choked off there is a good chance the engine will fail the NOx portion of the test. A hotter cam with no tuning will probably fail the HC portion. New plugs & wires and injector cleaner may help.
Old Oct 5, 2008 | 01:48 AM
any chance someone could post a pic showing where the egr hose goes, because I have no clue since it was cut off when I bought it....
stealthy95z
Aug 28, 2009 08:51 PM
cmtison
Apr 30, 2009 02:23 AM
7d1camaro
Jan 7, 2006 10:59 PM
mattvogt
Jun 26, 2005 01:51 PM
