Failed emissions NOx
The bypass decreases intake temps and increases emissions slightly, but nothing drastic that would cause emissions failure, let alone NOx testing.
It's been a while since I fixed my EGR issue, but I think I had roughly 15 Hg of suction.
There should be 12v going to the solenoid at all times.
Just tested it. It is sitting right around 18 at idle (tested it coming directly out of the engine) If I take one hose and go from there directly to the valve it doesn't do anything. If I push the diaphragm in then put my finger over the inlet it will stay open but I can't get it to open with suction.
I will say idle changes very slightly when I connect it (about what I would expect from stopping a vacuum leak) and I can feel the diaphragm shaking slightly. Think I should just go head and replace the EGR?
EDIT: Also when I rev it with my finger on the diaphragm it vibrates quicker but doesn't actually suck it in.
Whats the difference between a EGR for an automatic and one for a stick?
BTW for some comedic relief. Called the local GM dealership to see if they could calibrate my speedo the response I got was "why?" Because I changed the final drive "okay..." Can you do that? "no" Serious? "Changing the gearing wont change your speedo" then he proceeds to tell me it is because I have it set on kmh not mph. I tell him I don't it displays both "No there is a way to switch it, that is what it sounds like to me"
![Icon Lolsign](https://camaroforums.com/forum/images/smilies/icon_lolsign.gif)
![Icon Screwy](https://camaroforums.com/forum/images/smilies/icon_screwy.gif)
If it isnt that I can honestly say I am at a loss. =(
The new EGR worked fine out of the car but it will not actuate in the car. The old one works fine out of the car as well.
This is running a hose from the engine directly to the EGR bypassing the solenoid.
I am lost. Ideas?
EDIT: Found this on another board
Look at the old EGR valve and see if it has a "N" (negative)or a "P" (positive) as the last digit in the part number.
If it has a N it should open while engine is running when applied vac and should make the engine stumble.
If it has a P than it wont let the EGR function, even with vac applied, until the ex. has enough backpressure. You can usually get it to work if someone covers the ex. tailpie and sits there for a few minutes.
Wish I saw that before dropping the 80 bucks lol. If nothing else it is 80 towards the $200 waiver.
I am lost. Ideas?
