Factory gauges?
Old Jun 21, 2007 | 08:18 AM
patman's Avatar
Default Factory gauges?
Does anyone know how accurate are the factory gauges are? I have a 2000 Z28 and the oil press. gauge seems a bit erratic (sp). Any one know?
Old Jun 21, 2007 | 08:19 AM
patman's Avatar
Default RE: Factory gauges?
double post...sorry[:@]
Old Jun 21, 2007 | 04:35 PM
usarmyrangrs's Avatar
Try replacing the sending unit. It's a cheap part and is easy to install.
Old Jun 21, 2007 | 04:48 PM
JD1969's Avatar
What do you mean by erratic? It is normal for it to move a bit as rpm goes und down.
Old Jun 21, 2007 | 06:56 PM
patman's Avatar
for example, at constant speed on the expressway, the gauge will drop from 60 psi to 40 psi, then back to 60 psi after about ten seconds or so....
Old Jun 21, 2007 | 07:17 PM
I guess the only way to monitor the actual pressure is to either install a standalone pressure gauge or to monitor it with a scan tool.
Dro94Z28
Mar 10, 2013 09:01 AM
snapp88
May 20, 2012 03:11 PM
edog2
Mar 8, 2010 06:16 PM
Andross
Oct 30, 2006 10:09 PM
