Fabricated radiator support brackets.
Just curious if anyone has fabricated a stronger bracket to help support the upper part of the radiator. I bought a new plastic shroud about a month ago and it's already cracked.
How are you installing the radiator? The service manual says you have to de-gas the a/c condensor and remove/install both condensor and radiator at the same time.
While this is not actually required, you have to bend the a/c pipes a bit to get the required clearence. Maybe there is a bend in how the condensor is installed causing the radiator to not be sitting properly??
bottom will fit in without it going in right, its how it mates with the a/c part that can get it all outa shape. found that with the 00 when i replaced the radiator, had to take the a/c condenser out part way to get it right. then the upper part fit perfect.
