exhaust manifold gaskets
#81
have you seen them? yes flex pipe sucks,,,, i mean leaks... exhaust shop can make the pipe whatever size you want with pipe bender machine. usually do your pipe for nothing.
#82
yeah im going to a exhaust shop tomorrow and geting 8ft 3inch pipe and 4 elbows 3inches
#83
#85
no i was going to try to make a custom pipe setup with that kit. are u saying im going to need that kit and a y pipe? i probably should go with a kit more like this then? http://www.summitracing.com/parts/sum-670147
#86
depends on if you want to dump exhaust in front of rear wheels. running two pipes to the back will not leave much room for clearance. to run one pipe to the back you will need a y in the pipe.
#87
Welly car is on stock config for stance it is not lowerd are u talking about speed bumps and such?
#90
here is the clearance i have its pretty much stock
this one is with the first tunnel brace and it hit everything. give you and idea of how it crosses over too. i had to modify the y pipe by having it cut and one side stretched so it can be connected.
here is what i got. give you an idea of the y pipe looks like.
