exhaust manifold gaskets
Old 10-15-2015, 07:00 AM
torque_is_good's Avatar
yep,
I used Pacesetter long tubes and pacesetter off road y pipe. I then used a magnaflow cat back but darned if i lost the cat and couldn't find it :-)
  #92
Old 10-27-2015, 09:12 PM
warmeck's Avatar
ok well i am about to take my exhaust to get installed tomorrow but i first need to put my headers on and get 02 sensors/02 extenders. my question is will my original 02 sensors work or will i need to get new 02 sensors and 02 extenders? i tried advanced auto for 02 extenders and they said i dont know what im talking about
  #93
Old 10-28-2015, 06:02 AM
yes original 02s will work. probly want to use new ones in a week or so. new headers have coating on them that burns off and can foul the 02s. here is 02 extention cables. 2X LT1 Oxygen O2 Sensor Extension Cables For GM Camaro Firebird Corvette 24"
  #94
Old 10-28-2015, 07:59 PM
warmeck's Avatar
5-8 BUSINESS DAYS OMG is there something local i can pickup like napa/autozone/advanced auto im finishing up the job tomorrow and need to be able to bring it over to the shop
  #95
Old 10-29-2015, 09:45 AM
i only needed one. the stock driver side was long enough. check with your local exhaust shops and see if they have one. do you have the 3 or 4 wire 02s
  #96
Old 10-29-2015, 05:36 PM
warmeck's Avatar
i have the 4 wire 02s. and craby i need your help BADLY im putting in my race headers/long tubes i got the drivers side in but i broke the sensor that was on the drivers side. no biggie i can replace but the other side dosent seem to want to go in no matter how hard i try to push it through and i have the car on jack stands but it dosent seem like its enough to put it in from the bottom so i have been working with the top... i have to put the headers in and then put everything back together so i can drive it over to the muffler shop on saturday to have my custom exhaust made and welded
  #97
Old 10-29-2015, 09:52 PM
lol, i put mine in with the engine. from what i have read you need to get the front of the car up high enough to allow you to feed it in vertical. dont do it without good support and secondary support. dont need anyone to get hurt. have you pulled starter and alternator.
  #98
Old 10-29-2015, 09:55 PM
you can also losen the 4 (or is it 6) bolts that hold the k member on and drop the engine a bit. or take front motormount bolts out and lift it a bit.
  #99
Old 10-29-2015, 09:59 PM
front one sensor is temp gauge and other above oil filter is oil pressure. one on pan is oil level sensor.
  #100
Old 10-30-2015, 04:04 AM
warmeck's Avatar
is there a writeup on where and how to remove the motor mounts and yes i have starter and alternator all out
Quick Reply: exhaust manifold gaskets
