exhaust manifold gaskets
Old Nov 18, 2015 | 06:17 PM
  #141
warmeck's Avatar
have a friend got his house broke into 2 times ,an it was someone he knew both times .was just figuring out who it was ,that's so true ,they need to get caught ,yes acdelco should work fine,i found having security cams helps ,I have them in my car an 2 outside,there cost is pretty cheap ,an I know people who caught others after putting in cams ,an was the same person they though ,cams don't lie
what car camera u got?
Old Nov 27, 2015 | 07:11 PM
  #142
warmeck's Avatar
whats the best way to remove a nut thats on a bolt. keep in mind i cant get to the bolt side this is for taking out the window motor.
Old Nov 27, 2015 | 11:12 PM
  #143
if there the ones im thinkin of they are studs welded in.
Old Nov 27, 2015 | 11:14 PM
  #144
i have used small vise grips
Old Nov 28, 2015 | 04:01 PM
  #145
warmeck's Avatar
i got it out finally lol windows roll all the way up good now. just waiting for my intake and new maf to be here so i can fuel up and go to the exhaust shop
Old Dec 3, 2015 | 02:14 PM
  #146
warmeck's Avatar
holy **** just long tube headers are the loudest thing i have ever heard omg. so Saturday i am going to the exhaust shop to finally get my exhaust welded up but they are not really interested in putting in new header bolts for me... which is sad=/ but we will see if i can convince them.
Old Dec 4, 2015 | 10:53 AM
  #147
95 camaro 406's Avatar
Default 170
I got 2 170 D angle cams one in back one in the front there adjustable so they only cover about 260 D HD 1080 ,I could not find anything at the time that would cover 360d ,but I put 8g card in each was more then enough about 8 hours run time , then they rewrite ,during the day they work great an low light as well in the dark there ok but not to far ,I did not spend a lot .but what i did was put those stickers that say warning under constant surveillence ,cvsi installed at each corner of the car ,an on the windows of the house ,an since then no hit an runs ,you can pay a lot for the same cams I think its was like 25.00 each at the time ,I would point them toward fron an back , the cards were like $5,00 each on ebay,I bought the stickers separately ,then I have one cam at the corner of my garage that sends signal to my laptop ,that is hooked to a power cord ,an with light on at night it sees the whole drive way , DV HD,i have not been using them lately ,but every now an then the one outside I turn on ,that one was 100.00 made for outside ,an see up 100 feet yes I love my new exhaust ,they are so hard to get to the bolts ,you need like 3 different wrenches one angled alot
Old Dec 5, 2015 | 03:54 PM
  #148
warmeck's Avatar
welp as i was getting my camaro towed to the exhaust shop my front wheel lugs flew off and the tired popped off luckily the tow truck wasent on the highway. i now feel like my old mechanic is trying to freaking kill me... i feel like he came at night and un- loosed my lug nuts.... because its so strange that all 5 of my lugs were lose and i didnt take that tire off this whole time that i was working on the car.... at this point i have bought cameras all around my house to watch for him to try to come back.
Old Dec 7, 2015 | 06:10 PM
  #149
warmeck's Avatar
got my exhaust done it sounds amazing.. will have some pictures tomorrow. but now i have ran into another problem. my oil pressure is reading 0.. from start to shutdown. i drove it from the exhaust shop back to my house which is 6 miles and it stayed at 0? is this just my gauge reading faulty? it just started this when i got it back. should i do an oil change/new filter and see what it does? oil change is about 2 months old but i havent driven the car in that time either. filter is about 2 weeks old as i changed it because i broke it doing header install lol. and a cherry on top is my wheel bearing hub assembly is ****ed so i now need to get new wheel hub assemblys and nuts for it... FML. i am really pissed off i didnt get that corvette
Old Dec 8, 2015 | 01:53 AM
  #150
check your oil pressure sensor. easy to bust off or damage when installing headers.
