exhaust
Old Nov 6, 2011 | 11:08 AM
1slowv6's Avatar
Default exhaust
I have a 2k 3.8 and i have a metal rubbing sound coming from under the center console
ive been able to pinpoint it to the exhaust rubbing against a crossmember that holds up a drain tube.
now im not sure if there is supposed to be something here that holds up the exhaust that fell off or broke because the exhaust is sitting on that cross section and causing a vibration in reverse and over bumps.
im going to go to an exhaust shop and have them weld up a hanger but i wanted to know if the car is missing something that is causing this issue.
if not ill just get the hanger welded and let me know if you want pics ill go take some really quick
Old Nov 6, 2011 | 11:57 AM
check the hangers to see if any are bent, it should not hang low enough to hit.
Old Nov 6, 2011 | 12:40 PM
BasicConcepts's Avatar
Technical User
There should be a hanger at the cat that holds that section up I had the same issue and just put a little chunk of denim in-between there
Old Nov 6, 2011 | 03:40 PM
Failed Devices's Avatar
you could also just unbolt that crossmember, it won't have any affect on your performance and handling; did it on my v6 and my ls1 as most aftermarket exhausts will hit the crossmember anyway.
Old Nov 6, 2011 | 05:35 PM
1slowv6's Avatar
yeah there is no hanger at the catalytic converter, its aftermarket. and im guessing they didnt put the hanger back where is was
which is another problem im having the aftermarket converter is causing the 02's to throw a p0420 catalyst efficiency code. im gonna have a shop weld up the pipe tomorrow and ill worry about the code later...
anybody know of a way to trick the rear 02 on these cars since theres just one, i know the cat works just fine
Old Nov 6, 2011 | 08:30 PM
02 simulator is your best bet to keep it cheap. Or you can live with the engine light until you can get the code tuned out
Old Nov 6, 2011 | 10:39 PM
1slowv6's Avatar
yeah i could do that and delete the cat all together because i wouldnt mind firming up the shifts with a tuner .... for some reason i feel like the auto trans shifts WAY too early...
what is the "good" tuner for my car im new to camaros
Old Nov 6, 2011 | 11:20 PM
dyno tune if you can.
Transgo shift kit
Old Nov 7, 2011 | 01:17 PM
libertyforall1776's Avatar
You could also look into an aftermarket crossmember (and get a driveshaft safety loop to boot lol):
Drive Shaft Loops : UMI Performance, Inc.
But yes, get a hanger welded -- an aftermarket crossmember will not solve your vibration issue...
scottlt194
May 14, 2009 08:27 PM
famlyguy18
May 6, 2009 05:26 PM
dbess23
Sep 17, 2007 02:02 AM
javione
Feb 16, 2007 02:27 AM
jhop16
Jan 9, 2007 11:21 AM
