even more bad luck
#22
It has to come off the series II engine not the older series I 3800 or the even older 231 3.8L that had DLI. The part # from autozone and O'reilly's show 96-05 Series II including Supercharged. in 03 or 04 the Sereis III engine came out and it's module is NOT the same.
Massey
Massey
#23
Ok so i ordered a new icm. It was only $10 so if its not the problem idc i got a new icm for $10. I also noticed something while removing the icm. There is a wire for ground attached to the driver side head. It was loose so i tightened it and still no dif. Any idea what the ground is for?
#24
thats the ground for the ignition modual on yours i think, on mine its the ground for the tach filter (black box taped to harness) but i think that was done away with in 95.
