Engine running rich.
Old Nov 11, 2012 | 12:39 PM
JakeYeah's Avatar
Default Engine running rich.
So its come to my attention that my engine may be running a little rich. What would be a way to fix that.
Old Nov 11, 2012 | 12:49 PM
BasicConcepts's Avatar
Technical User
any trouble codes? it could be a number of things, bad plugs and wires, bad coil, leaky injector, bad o2s, ect.
Old Nov 11, 2012 | 01:57 PM
jkeaton's Avatar
How are you arriving at this conclusion?
Old Nov 11, 2012 | 02:04 PM
JakeYeah's Avatar
Basic- No trouble codes, ran em a few days ago.
jk- you can tell just by the smell of your exhaust that youre running rich.
Old Nov 11, 2012 | 08:59 PM
jkeaton's Avatar
I wonder if mine is running rich. Shouldn't the computer prevent that and if it could not, it would set a code?
Old Nov 12, 2012 | 06:47 AM
torque_is_good's Avatar
ALDL OBD1 OBD cable OBDI OBD2 engine codes
buy the cable and log the data; you'll know right quick
Old Nov 13, 2012 | 07:23 PM
test evap system, check 02 sensors for fouling, check plugs for fouling, have injectors cleaned and flow tested look far any vacuum leaks, exhaust leaks, check maf to see if dirty, check air filter, fuel filter.
strokerracing
Jul 11, 2011 06:59 PM
orlando_trudeau@yahoo.com
Jun 16, 2009 12:35 PM
atlanta2008
67-69 V8 Tech
Sep 13, 2007 06:24 AM
T10wheels
Nov 7, 2006 05:28 PM
beneharris
82-92 V8 Tech
May 11, 2006 01:25 AM
