engine is misfiring
Old May 2, 2007 | 08:14 AM
rayden7157's Avatar
Default engine is misfiring
Hi all, well this is my first camaro a 97 It started running real rough and the check engine light came on gave a p305 code. I'm gonna change the plugs and wires do you think this will solve it or is it something else that could be wrong. Any help is appreciated. Thanks
Old May 2, 2007 | 04:27 PM
Default RE: engine is misfiring
The code means that cylinder #5 is mifiring, check the plug & plugwire. If still bad check that injector # 5 is being fired,
Old May 2, 2007 | 07:47 PM
usarmyrangrs's Avatar
Exactly, Pete. Do as suggested. Inspect the plug and notice whether it's gapped properly. Also check the no. 5 plug wire entirely. Rather, I'd go ahead and replace the plug. If this doesn't solve the problem, other, more involved problems lie ahead. 9 out of 10 times, however, when it comes to misfiring, hesitations, sputtering, and stumblings, the ignition system is at fault, not fuel or compression.
tv195
Jul 31, 2011 08:01 PM
JeepGuy12
Aug 21, 2010 05:35 PM
camarofreak1990
Oct 3, 2008 01:58 PM
dumbnstupidone
Mar 23, 2008 05:47 PM
94 z28
Mar 16, 2008 10:58 PM
