Engine Help???
Old Apr 8, 2012 | 10:12 PM
Camaroboi22's Avatar
Default Engine Help???
whats the easiest way to take out a lt1?
Old Apr 8, 2012 | 10:15 PM
BasicConcepts's Avatar
Technical User
the bottom
disconnect the electrical from the computer and the grounds
disconnect your fuel and front brake lines
unbolt the struts from the towers
unbolt the 6 subframe bolts
and drop her down
there is a little more involved with it than that but with some basic hand tools and a engine lift its pretty easy. i had my LT1 out in about an hr and a half.
Old Apr 8, 2012 | 11:41 PM
what about a way with out the lift? also taking trans out with it
Old Apr 9, 2012 | 08:34 AM
out the bottom is still the easiest way. trans comes out with motor.
Old Apr 9, 2012 | 08:36 AM
torque_is_good's Avatar
you need a cherry picker (engine hoist) to lift up the front end of the vehicle off of the engine/tranny
yes, the same type of cherry picker for yanking engines from the top
I suppose if you had the local weightlifting team over they could probably lift the front end off but it would be tough to work around all of those brawny women as they were holding up the front end
onefastls1
Jan 2, 2013 01:45 PM
martynlutherking
May 25, 2010 11:12 PM
Chevykicksbut
Oct 28, 2009 07:14 AM
drabina
Jul 25, 2008 08:56 PM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
