Engine harness removal at the firewall
Old Sep 26, 2017 | 05:18 PM
rogue1's Avatar
Default Engine harness removal at the firewall
I looked at several threads for this but didn't see anything. I am going to do an engine swap on my 2000 camaro and I am have removed everything from the engine compartment but the harness. I can get the connector out of the firewall but how does it come apart. I can't see trying to run all of the wire connected thru that hole.
Old Sep 27, 2017 | 09:22 AM
there is a plug there. be best if you download the factory manual, best directions for removing engine and does show removal of harness. brb
Old Sep 27, 2017 | 09:26 AM
go here and download your year manual. https://www.mediafire.com/?40mfgeoe4ctti click your year, 2000 pretty much covers 00-02.
found here on the forum https://camaroforums.com/forum/camar...d-views-73894/
Old Sep 27, 2017 | 09:31 AM
the harness plug is on the passenger side, under dash, have to take kick panel and under dash cover off to get to it.
camaro maniac
Aug 20, 2007 11:40 PM
SpecterGT260
Jun 28, 2007 09:10 PM
Asimplename
Jul 19, 2006 05:41 PM
ratbikeharley
May 3, 2006 01:29 AM
kdurlin
Sep 3, 2005 08:26 AM
