Engine acting weird?
Old Feb 23, 2013 | 12:20 AM
NSKY's Avatar
the plugs are less than 5000 miles old. and yea whoosh sorta noise and hot smell. but the smell only after a long drive.
Old Feb 23, 2013 | 12:52 AM
be a good idea to at least test the exhaust to see if the cat or muffler is plugged. cat can plug and go to pieces then plug the muffler. dont need to drill if you have 02 sensors on both sides. just take one out
Old Feb 23, 2013 | 01:20 AM
NSKY's Avatar
Um i dont have a cat. Guy who had it before me removed it. Just found that out.
Old Feb 23, 2013 | 06:55 AM
better test anyways, if muffler is plugged it will do same thing as plugged cat.
Old Mar 4, 2013 | 10:47 PM
NSKY's Avatar
Found the problem. The number 3 wire from coil pack to spark plug was burnt in half. Could only see it after the car was on a lift.
Old Mar 5, 2013 | 06:59 AM
lol,,, thatll cause a misfire. good deal. cheap fix.
Old Mar 7, 2013 | 08:13 AM
Plan on replacing that coil in the next few months. When an 80,000 Volt coil needs to fire and can’t it tends to get very hot. The spark will leak out of the coil. This leakage will cause carbon tracking. The coil will remember that leakage and it will start following that carbon path instead of the plug wire. It is just a matter of time.
Old Mar 8, 2013 | 08:31 AM
NSKY's Avatar
Replaced pack and wire
EagleRex
Aug 16, 2010 02:07 PM
95camaro95
Jul 6, 2010 01:05 PM
Ofallah
Jun 12, 2010 11:46 PM
liltonz609
May 18, 2010 06:45 PM
rokinv6
LS Series Tech
Feb 28, 2010 10:52 PM
