Electrical Gremlins!!
Old Oct 5, 2014 | 06:52 PM
subysti's Avatar
Default Electrical Gremlins!!
OK need some help here with a schematic or maybe someone knows this already. Daughter has a 96 convertible base with 3.8. Sometimes the electrical system shuts down some items. I know there is either a short somewhere or a relay cycling. So far the systems that don't work when this happens is the stereo, power windows and the power top. Eventually a few minutes later they start to work again. I looked in the Chilton's manual but according to those schematics there isn't any wiring in common with these 3 circuits. Anyone have better schematics or an idea of what's causing this? thanks a lot for any help.
Old Oct 5, 2014 | 07:18 PM
sounds like it could be the body control module, have a look here
https://camaroforums.com/forum/93-02...-repair-52062/
How To Fix Intermittent Windows, Radio and Locks
Old Oct 5, 2014 | 09:07 PM
GaryDoug's Avatar
The RAP (Retained Accessory Power) supply is in common with all three. Like craby says, most likely the BCM since that controls that supply. A very common problem.
Old Oct 6, 2014 | 01:37 PM
subysti's Avatar
Thanks guys, the BCM was exactly the problem, I think. Took it out and in fact did find a cracked solder joint. Checked them all with an eye loupe and only found the one where it was guessed to be on the back of a relay so hopefully that's it. Now on to engine problems. Thanks again, I never would have found that otherwise.
htownZ
Sep 18, 2013 12:32 PM
mhobryan
Feb 26, 2012 01:32 PM
je$$up97
Dec 5, 2011 10:52 AM
matthew405
Apr 13, 2009 09:41 PM
nuttyprofessor
Sep 22, 2007 10:20 AM
