Electrical connector on oil pressure sending unit
Does anyone know how to remove the wires from the molded plastic connector that plugs into the oil sending unit? Does anyone make a replacement with pigtails that can be spliced in? Mine has apparently a break in the wire where it enters the molded plastic and is driving me nuts! Sensor is good. Think a salvage yard would let me cut one from a yard car or make me buy the entire harness?
Yes. I either had O oil pressure or it was maxed out before, unless I was messing with the connector while the engine was running. Ohmed out the connector once I removed it and apparently the wire is broken where the crimp is gong into the plug. Spliced the new one in and reading about 1/2 gauge when cold and between 1/2 gauge and 1/4 guage at running temp idle.
did it fix the problem.
