Egr diagnostic issues
Old 06-28-2012, 02:23 PM
woodstock's Avatar
dont leave me hangin guys! please.
should i,
A. remove upper intake/throttle body. and clean.
B. remove egr and try to blow deposits out of engine and lines
C. seafoam
D. C4 the gas tank and detonate!
Old 06-28-2012, 03:05 PM
Originally Posted by woodstock
The Haynes manual states
"Problems with the digital egr control circuit or egr VALVE will set codes 75 76 or77"
You replaced the EGR valve, and it's still the same, so the valve is out of the equation. "Control circuit" means you have an electrical issue. Could be the wiring, no signal from the computer, etc. Don't go digging into the mechanics of the engine, you won't cure anything there. Here, pull up a chair, and pop open a beer or two: Part 1 -How to Test the GM EGR Valve (P0401, P0403, P0404, P0405, P1404, P1406).
Old 06-28-2012, 05:33 PM
woodstock's Avatar
i took some notes and will go fool around with my multimeter this weekend.
i still think the upper intake is clogged, we will see.
one question, the egr is brand new obviously, can i remove and reassemble with the same gasket? as long as i am careful.
thanks as usuall, perfect site i will use it alot.
Old 06-28-2012, 06:15 PM
Chances are the gasket hasn't baked itself on, but might as well approach with caution. You could always use a dab of hi-temp RTV if you get a little lifting.
Old 06-28-2012, 08:45 PM
Old 06-30-2012, 10:59 AM
woodstock's Avatar
thanks for the diagrams. will help alot. where did those come from?
i will be running some tests soon il keep the progress posted
Old 06-30-2012, 11:03 AM
He has a factory service manual (the big book) for his car, as I do for all my cars. It's a wise investment, and deals can usually be found on ebay.
Old 06-30-2012, 08:50 PM
^^^ yep its a factory service/shop manual. 95 is a two volume set. wow this guy has all the updates. 1995 CHEVROLET CHEVY CAMARO + PONTIAC FIREBIRD FACTORY SHOP SERVICE MANUAL ++++ on eBay!
Old 07-05-2012, 12:06 PM
woodstock's Avatar
Checked for vacuum leaks today, there were none.
going back outside to trace the wires to the ecm. for a second time. maybe find some corrosion or something i didnt see
still no progress on this issue
again, with the key on, and engine not running
the plug displayed no voltage anywhere and would not test for resistance.
  #20
Old 07-05-2012, 02:28 PM
should be getting power to the brown wire with the key on. test to see if its gounded.
Quick Reply: Egr diagnostic issues
