Driver window not sealing
#21
![](http://imageshack.com/a/img542/1312/juid.jpg)
#22
have you looked up in there to make sure the window is in the lower window frame correctly. had my truck frame rust out and one of the rollers came off. the window would be up all the way but would not close. took it apart twice before i noticed the frame was a goner
#23
The window has been changed cause they left the roller in the vertical track that broke off when they put another window in. I found that out cause window didn't go down all the way.
#24
we need someone with a vert to measure there window when its up to see if yours is going up all the way. if you see one in a parking lot get the tape out and see what its sayin. either the window is not going up all the way, adjusted wrong or the body is somehow not right. im thinking its inside the door, like the regulator being bent or damaged
#25
#26
man, what a puzzle. dang its been to long sence i had my door apart and i cant picture everything. we have a window in motion on here somewhere ill see if i can find it. if the stop is in the front try adjusting the front down. if in back try adjusting back down. need to see if the rest of the window goes up farther. when i changed my regulator on that side luckily i didnt have to adjust. thank god.
#27
ha i found it at shbox. a little down the page click were it says vido showing regulator in motion. http://shbox.com/page/windowmotor.html
#28
ha i found it at shbox. a little down the page click were it says vido showing regulator in motion. Power Window Motor
The lady I bought it from said she bought it from a mechanic that got it from an auction and rebuilt engine and sold it. The engine has like a very lite tap/knock on driver side under 2000rmp after 2000 its gone. Been that way since I bought it but its never got any worser. The title is clean, so no accident evidents there only the front bumper that been repaint if not changed and repainted.
