Driver window not sealing
Doesn't hurt window alignment if the door gaps aren't perfect, as long as the door stays that way. Just would hate to adjust the window only to have the door adjustment tweak at the hinge again. Getting door to fender to window to top adjustments perfect can be a real beech. Hope you have a good head of hair....for pulling out of frustration!
I Silicone both t-top weatherstrip mounts. The two seal that are like double sided tape went bad and leaked. The weather strip looks different like left or right on the ends. I even switched passenger and driver t-top seals and still same gap.
dang is the roof crooked, mine goes up a little to far but that easy fix. on my hard top i have 14 and 3/4 in from the edge of the lower window seal to where the window hits the upper seal, door open at the hump towards the front i have a little over 14 3/4in and all the way to the rear of the window i have 14 1/16. is your window going all the way up to the front guide on the door?
As far as my eyes can tell I don't see a crooked roof. T-tops look fine and latch good no leaks up there.
Damn careless sloppy shops -- had the same thing happen with BOTH my Camaros. One fixed it, the other paid a damage claim. You have to babysit and watch everything shops do -- they never treat your car as if it was their own.
I get the front to work that going past the factory marks tho. For the 5 inches in front of the t-top to the back im hitting the max point that there's no more adjustments.
Yeah they are careless I seen so many in the junk yard that has it smashed, its like they dont check where the jack is. Then they mess something up under there and dont tell you about it or tell you they found a problem and have you pay for what they did. Then hope bending it back right dont brake metal or fiber glass.
