Drive shaft out of balance
Old Sep 10, 2012 | 08:23 AM
KcLive's Avatar
I might just have to do that... quick question... does the cover over the drive shaft have to be there for anything or if it is banged up from being in the ditch can I remove it without any problems?
Old Sep 10, 2012 | 11:56 AM
What cover? There is a a center support and the support between rear and the trans. I can not think of anything down there that is just a cover.
Old Sep 10, 2012 | 03:06 PM
BasicConcepts's Avatar
Technical User
im pretty sure hes talking about the torque arm, and if so no you NEED that it keeps your pinion angle right. and if its bent you need to replace it before you start driving the car... unless you like replacing parts
Old Sep 15, 2012 | 08:01 AM
KcLive's Avatar
Yes, I was talking about the torque arm... and from what I have noticed it looks like it is fine. I should hopefully have another driveshaft to drop in here soon and hopefully that will take care of this shaking issue.
Old Sep 15, 2012 | 04:37 PM
Greg08's Avatar
I had no clue I could purchase an aluminum driveshaft for so cheap. I need one
Old Sep 16, 2012 | 05:47 AM
Edwardgp's Avatar
I didn't realize they were that heavy.
Old Sep 16, 2012 | 01:00 PM
Technical User
ya the 2 piece is disgustingly heavy
Old Sep 16, 2012 | 01:03 PM
Greg08's Avatar
On the 95 z28 the driveshaft is pretty heavy. Idk if its a 2 piece though
Old Sep 16, 2012 | 01:05 PM
Technical User
no only the V6 got the 2 piece. somewhere on here there is the weight of the different shafts, i may be able to find it.
Old Sep 16, 2012 | 02:02 PM
  #20
I weighed my 3rd/4th gen one piece driveshafts when I did a change...
Steel: 16 lbs.
Aluminum: 12 lbs.
Keep in mind, although the two piece driveshaft will be a bit heavier, that's not spun weight (the actual weight of the shaft), as part of it consists of the bearing block.
