Door stuck locked
Door stuck locked
The drivers side door on my 95 Z28 is stuck locked. (Been going in Dukes of Hazzard style for a few days 😊 Lock/unlock button won't move and the key will not even turn in there to open it. Would this be the lock actuator?
woh so you cant get the door open. makes it tough to get the door cover off, need to get in there and see if one of the parts of the window came lose and is jamming it. was it working normal up until it froze up?
It was working perfectly until this. No sign of problems. Not even rattles from inside the door. The car has 86k original miles on it, I've had it since 75k, and never had problems, perfect interior. I was able to get the door open by lifting the handle on the outside and just pushing back and forth on the door. I only did that once, just to see if it would open. I was at a gas station and was not where I could investigate the problem. I imagine it would work again but the door never unlocked.
download the factory shop/service manual here https://www.mediafire.com/?40mfgeoe4ctti click the 94svcmsn
more https://camaroforums.com/forum/lt1-l...25/#post639865 this is in the factory shop/service manual
