door lock F'd up from theft
Old Oct 26, 2010 | 12:00 PM
RFxCamaro's Avatar
Originally Posted by 1augapfel
From your pictures it doesn't look like the damage to your door is bad enough to prevent installation of another lock cylinder. I mean there's a horseshoe-shaped spring clip inside the door that holds the cylinder in place and tight to the door. Is the door hole damaged badly enough to prevent lock cylinder "normal" installation?
it wobbles in the socket it i where to turn the key it would turn the entire cylinder
Old Oct 26, 2010 | 12:02 PM
1augapfel's Avatar
Oh, bummer. I guess I'd go with Quiksttel or PC7 epoxy then.
Old Oct 26, 2010 | 12:06 PM
just so you know cost difference you should price a door at the wreckers and see if you can find one the same color.
Old Oct 26, 2010 | 03:22 PM
osduck5's Avatar
Doors can be bought around here for $100 and I have seen them on craigslist for as cheap as $50 with the glass. If you have to replace the lock set, I purchased a set from camarocentral for around $40 shipped. Put them in last weekend and they worked great.
Old Oct 26, 2010 | 03:37 PM
You know, screw the factory lock, why be like everybody else? You already have one hole, just drill another one and be "different":
Old Oct 26, 2010 | 04:15 PM
osduck5's Avatar
LMBO! I bet they have a home airconditioner mounted in the back window too! LoL
Old Oct 26, 2010 | 04:19 PM
Chaotic94's Avatar
September 2011 ROTM
Very nice 69! I may do that with mine
Old Oct 26, 2010 | 06:26 PM
Grandpaswagon's Avatar
The best thing about that is if you are in a really bad area, just loop a bigger chain and lock through the holes. Instant increased security!
Old Oct 26, 2010 | 08:22 PM
BasicConcepts's Avatar
Technical User
its better than an alarm
Old Oct 27, 2010 | 03:25 AM
  #20
RFxCamaro's Avatar
yea but for $10 i can get quicksteel and also i have aftermarket actuators and power windows so it would be a ***** to reinstall all that. By the way the aftermarket power windows work so much better than all the stock power windows ive seen in maros. It cost $60 for the full set both windows i highly recommend it.
WayneW
May 18, 2013 09:04 PM
KissMyTush
LS Series Tech
18
Mar 14, 2012 12:54 AM
Hvacman
Feb 12, 2012 09:15 PM
19Z95
Dec 21, 2009 10:50 PM
bd92rs
Dec 6, 2009 08:09 PM
