Do I need a battery or something else?
Old May 16, 2008 | 07:37 PM
dans02vert's Avatar
Default Do I need a battery or something else?
Hi I have an '02 z28 convertible. There is a gauge below the speedo that measures voltage. I've noticed two things. This needle bounces anywhere from 1/8 to 1/4 of an inch in either direction, it is not steady like the other gauges. I've also noticed at night, my headlights seems to flocker a bit just as the needle bounces. thanks
Old May 16, 2008 | 07:54 PM
Big_Bird_1985's Avatar
Default RE: Do I need a battery or something else?
It is either your battery or your alternator is about to go out on you. It couldn't hurt to make sure your serpentine belt isn't worn or wobbling on a pulley. Hope this helps
Old May 17, 2008 | 01:35 AM
djsevilways's Avatar
i agree with big bird but you also might want to check the wiring also
libertyforall1776
Feb 24, 2014 02:11 PM
Dana
Dec 20, 2013 02:56 PM
Amy Z28
Feb 22, 2012 02:58 PM
iLL95
Nov 8, 2011 04:04 PM
typeomang
Feb 9, 2009 10:30 AM
