desperate for help!!!
Old Nov 1, 2008 | 10:46 PM
Mustangfighter96Z28's Avatar
Default desperate for help!!!
finally got the engine rebuilt and back in the car, but now it won't shift into gear while the car is running. it will shift with car off but if I try to start it in gear the car rolls forward or back even with the clutch to the floor. already bled the system and the clutch kit is brand new so I have no idea what could be wrong or what to do now. all I know is I want my car back!!!!!!
Old Nov 1, 2008 | 11:45 PM
95slvrZ28's Avatar
Default RE: desperate for help!!!
Well that sure sounds like a clutch issue to me...are you sure everything is set up correctly? Did the system bleed correctly (the petal doesn't just sit at the floor)? Are you sure the clutch fork is engaging the throwout bearing?
Old Nov 2, 2008 | 02:39 PM
everything is installed right and the shift fork looked fine when the engine was out. I put in a heavier clutch kit than the factory one, are there adjustments that need to be made with a heavier clutch kit?
Old Nov 2, 2008 | 03:19 PM
95slvrZ28's Avatar
You shouldn't have to make any further adjustments. It sounds like the clutch isn't disengaging if the car rolls forward or backward when you try to start it in gear. This sounds like it could be an improperly bled system or improperly set up (i.e. the throwout bearing is not pushing against the pressure plate correctly and thus the clutch won't disgenage)
Old Nov 14, 2008 | 01:35 AM
im74d's Avatar
Is there alot of tension on the clutch fork. I had a scenario that the clutch fork came off the throw out bearing and reinstalled the tranny without realizing it. That sucked!!!! Had to drop tranny again to put it back on. You can get a cheater bar and check to see if you can manually move the throw out bearing directly with the clutch fork or if its just wedged in between.
texas_RS
Mar 19, 2011 04:19 AM
z28man1182
Sep 25, 2009 08:23 PM
1986camero
82-92 V6 Tech
Jun 11, 2009 04:12 PM
chevman00
Sep 24, 2007 08:27 AM
