new car needs desperate help
Old May 9, 2009 | 12:53 AM
1986camero's Avatar
Default new car needs desperate help
the car barley turns over, but when it does i hear this load banging sound, almost like BANG BANG BANG BANG like metal on metal. the next problem is, is that the car started loosing speed on the freeway and the oil temp started getting red and bright red, then i started loosing speed even after i down shifted and hit the gas. other than that the cars in good shape, but the key i got from the owner doesnt lock the doors or even unlock the trunk.
any help would be great.
the engine is a 2.6 v6 i think
Old May 9, 2009 | 01:39 AM
mtn_maro's Avatar
theres two keys. one door one ignition. sounds like rod knock. needs a lower end rebuild
Old May 9, 2009 | 01:50 AM
1986camero's Avatar
lower end rebuild? in a price range how much would that be?
Old May 9, 2009 | 02:11 AM
mtn_maro's Avatar
in other words from the head gasket down. well my old roommate had to do one to his eclipse...doing the work ourselves other than the machining it was...$500-800 i believe. not sure though.
Old May 9, 2009 | 02:30 AM
1986camero's Avatar
machining of what? well its alot older so it should be a lot cheaper than an eclipse?
Old May 9, 2009 | 02:33 AM
mtn_maro's Avatar
if you have rod knock then your crank might need some machining. you might need a new rod. you wont know til you pull the oil pan and look. you might be able to do it cheaper but idk for sure.
Old Jun 5, 2009 | 05:34 AM
the marpet's Avatar
Just buy a new engine, it'll cost the same... 500-800 for a rebuild or 1000 for a complete new engine hmmmmmm........ I wander which one sounds smarter????? Next time when you hear a knock stop immediately.... Just CS for you next time.... Machining is another $300 job on top of the price for parts.... 2.8 V6 cheap easly found new 3 year unlimited warranty, mean if you break a part its covered.... If I can find where i bought mine from I'll post it.
Old Jun 11, 2009 | 04:12 PM
RubberDucky's Avatar
I got my replacement 2.8 for the same problem for 250$.
texas_RS
Mar 19, 2011 04:19 AM
z28man1182
Sep 25, 2009 08:23 PM
Mustangfighter96Z28
Nov 14, 2008 01:35 AM
chevman00
Sep 24, 2007 08:27 AM
