dash face gauge question
Old Jan 2, 2009 | 09:35 AM
JohnCisco's Avatar
Default dash face gauge question
bought a 2002 SS that has a white dash face gauge (not sure what exactly to call it) and I was having problems where the needles would light up but you couldn't see any of the numbers on the gauges, they wouldn't light up. Couldn't find anything wrong with any of the wiring so I took it to a mechanic and they pulled it and said someone simply placed the white face over top the stock one and not everything is lining up but the lights are on behind it. Not sure if they pulled it from a different year camaro but the high beams and osme of the lights are in the wrong place on this face. The mechanic didn't want to pull all the needles to pull the face off and told me either take a razor and cut the old face off or pull the needles myself. They said it wasn't sticky or anything on the backside of the white face cover, it was just sitting in there.
Question time, if I pull the needles can they only go back on one way so none of the readings will be screwed up? Or can they be put on incorrectly which would give incorrect readings?
It's going to bea pain to be careful cutting it out so I'm looking for the easiest, but also the correct way, for removing this face cover.
thanks
Old Jan 2, 2009 | 06:06 PM
cbr600rx7's Avatar
Default RE: dash face gauge question
The term you are looking for is gauge over lay. It sounds like some one might have picked up a cheap one and throw it on there or maybe didnt line it up right. For the needles there is only one real way they can come on and off so that should not be a issue for you.
iCOMEwhite
Mar 23, 2010 10:54 AM
94Z28CamaroCoupe
Jan 6, 2008 09:39 PM
Ophee
Aug 19, 2007 12:03 PM
Teal_93
Mar 3, 2006 01:47 AM
