DAMN IT. Coolant hose popped off and intake sucked coolant in.
Now it smokes all out the intake, huge clouds and it pushing white gunk out. Also my oil is milky white, is it a blown head gasket or did the coolant travel into the intake down into the oil? (Which I highly doubt I just want some false hope.)
And what about the gunk being pushed out the intake? Even if I changed the oil wouldn't that just fall back in? Also, when I fill the radiator it just keeps draining out. I don't see leaks. Is that a sign of a blown gasket?
It would pass through the rings and get into the oil from the cylinders. and if you get too much water in a cylinder you can either bend a rod, break a piston or blow a head gasket. Change the oil first. Also with the way the intake is on the 3.4L engine it may just be holding some water and you will be burning it for a while. Also some of that water may have condensed in the cat or elsewhere in the exhaust and will be there for a while unless you get the engine good and warm on a drive.
Didnt you just put new head gaskets on?
Massey
Massey
Draining out where? Does your oil level go up along with the missing water?
Massey
depends on how much. a little will burn off, alot will drain past the rings if let set. if running it can blow head gaskets, bend valves, bust pistons, bend or break rods depending on how much water. if you got white stuff coming out the exhaust and coolant in the oil it was a mess of water and or somethings busted.
