Crazy code 14 wont go away?
Old Jul 19, 2020 | 08:44 PM
Jack Loftice's Avatar
Default Crazy code 14 wont go away?
94 firebird formula lt1 .code 14 after changing ecm twice ,ect twice.And all pinouts test GOOD!
Please ,any crazy idea's?
Old Jul 20, 2020 | 10:15 AM
peterpar's Avatar
When you say the pinouts test good, is that testing to see if the ECT wiring has shorted to ground or there is continuity in the wiring between connectors? A wire shorted to ground will set the DTC 14 code.
Old Jul 20, 2020 | 11:46 AM
Yes i double checked for broken or shorted wire in fact replaced the yellow from ecm to ect as well as ground....just got info that maybe transmission temp circut may cause this?? Im getting code from my snap -on modis plus ,bit weird thing os the code is stored in transmissio department in scanner not engine dept.???
Old Jul 20, 2020 | 01:34 PM
peterpar's Avatar
The transmission fluid temperature sensor uses the same sensor ground as the ECT.
File Type: pdf
Old Jul 20, 2020 | 08:55 PM
Yes...and thank you for schematic but code is specific to signal wire ,yes?
Old Jul 20, 2020 | 11:59 PM
peterpar's Avatar
Yes, but if the sensor lost it's ground and was the same voltage potential on both sides of the sensor thermistor, that would effect the voltage signal being sent to the PCM. Voltage will always take the shortest path to ground. If a sensor shorted and allowed a voltage to pass through it, all three sensors with a common ground would now be the same potential on both sides of the sensor thermistors. At least that is how I understand it, but I could be wrong.
Old Jul 21, 2020 | 12:57 PM
abosolutley..understandable thank you for different perspective,gonna get inside of that valve body and replace all electrical from trans to ecm ...wish me luck...will post results!!
Gp Love James
Aug 24, 2019 02:41 PM
warghost69
May 13, 2012 04:37 PM
SpecterGT260
May 17, 2009 12:04 PM
buckmaster
Aug 8, 2007 01:43 PM
