Crank Seal Leak
Old Sep 12, 2011 | 06:10 PM
royco95's Avatar
Default Crank Seal Leak
Changed the timing cover and water pump on my 95 3.4, and cant get the crank seal to stop leaking. Its been changed 3 times now.. Was usually in a hurry so the motor was a little warm.. Anyone know the remedy?
Old Sep 13, 2011 | 12:24 AM
Possibilities:
Broke seal while installing
Seal installed wrong
Wrong seal
Groove worn on crank nose, try a sleeve.
Old Sep 13, 2011 | 11:39 AM
Originally Posted by z28pete
Possibilities:
Wrong seal
I'll add one to that. It is a ugly one. To much play between the sealing suface (the crank) and the seal mount (timeing chain cover). This would mean a failing front main bearing.
Incorrect instalation process/tool would be my number one guess with damage sealing surface (crank grooves) not too far behind.
Old Sep 14, 2011 | 10:22 AM
royco95's Avatar
Thanks guys. We'll be looking at it again this weekend. There wasnt any oil leaking from the crank seal before this repair (timing cover and w pump), but it could still be the front main bearing?
Old Sep 14, 2011 | 11:14 AM
I would not think so. Normally a customer will start with a small leak we replace the seal it goes a way for a little but then comes back. Over time it get to the point a new seal will not even help. Without some other issue like the motor over heated or the oil pressure dropped I doubt its the main bearing. I was just throwing it in as it is possible.
keaboi
Jun 18, 2011 12:41 AM
69Muscle
Jan 5, 2010 03:57 PM
typeomang
Nov 21, 2009 08:37 AM
ToledoG90
Jul 12, 2008 06:02 AM
CRanMaro99
Sep 22, 2007 12:43 AM
