A couple M6 questions
Old Dec 21, 2011 | 03:06 PM
KeithB's Avatar
Default A couple M6 questions
What was the first year that received the better M6 trans?
Will the M6 from a LS1 car bolt into a LT1 car and to the LT1 motor?
Thanks
Old Dec 21, 2011 | 03:24 PM
KeithB's Avatar
I found this chart that lists the various applications of the T56
Borg-Warner T-56 transmission - Wikipedia, the free encyclopedia
So it looks like the only weak T56 was the 93, rated 350 lbs torque
Old Dec 21, 2011 | 03:47 PM
Oh good! Anything else you need help with?
Old Dec 21, 2011 | 03:58 PM
KeithB's Avatar
So the LS1 tranny use different wiring and speedo hookups?
Old Dec 21, 2011 | 04:24 PM
Yes,
The weaker trans was not a MN6 it was the M28 there is also a M29. They are not really weaker persay. They have better first gear ratios but because of that the transmission sees more internal torque. So the parts are not really weaker as much as the design creates more stress. First gear in a M28 is 3.36:1 while first gear in a MN6 is 2.66.
So if you put a M28 transmission in a 94 that has 3:42s in it it would be about the same as adding a 4:11 Rear.
Old Dec 21, 2011 | 04:42 PM
Thanks
The simple answer is yes, no, and it depends. The input shaft of the LS M6 is longer than the LT's. Clutch setups are different too.
This may help: LT1 to LS1 T56 swap
Old Dec 21, 2011 | 05:18 PM
KeithB's Avatar
Thanks
chase0990
Jul 11, 2010 10:08 PM
toxicat
Apr 6, 2009 01:29 AM
rpope904
Jul 6, 2008 04:11 PM
whammer3024
Aug 20, 2007 10:03 AM
redt_top
Mar 14, 2007 11:00 PM
