correct OBD1 scanner?
Old Oct 13, 2012 | 07:15 AM
goodwrench67's Avatar
Default correct OBD1 scanner?
Ok, I bought an OBD1 scanner to adapt to my OBD2 connector in my 95 car using the diagram http://shbox.com/1/xraycable.jpg But, the scanner I bought only has 3 pins. Did I buy the wrong one? Part # 3123 from Innova. I bought it at O'reily's auto part store.
Old Oct 13, 2012 | 09:51 AM
To read codes from your car you need a real OBDI scanner, what you purchased is a plain BOBDIcode reader, and it won't work with your car. Get a OBDI scanner and then use the adapter cable.
Old Oct 28, 2012 | 03:53 PM
libertyforall1776's Avatar
Get a Autoxray EZ-Scan 6000 -- and you'll be fine.
Old Oct 29, 2012 | 02:51 AM
mfmfim's Avatar
Innova makes very good code readers. I have a '94 Chevy diesel 3/4 ton truck and a '98 Chevy Camaro. Having two older vehicles, I needed a code reader. I bought the 3120b which does OBD I and OBD II. I'm very happy with it. I purchased it on Amazon for $150.
I took a look at your .jpg, scary! You could have done this much with a wire.
Old Oct 29, 2012 | 07:24 AM
jkeaton's Avatar
Actron CP9185 is a good one as well. Works on my 94 OBD1 as well as OBD2.
Old Oct 29, 2012 | 07:57 AM
torque_is_good's Avatar
yup yup or the older 9145
you don't need a power cable either, just the battery within the unit itself
you aren't going to find a $99 cheapo reader which works
Old Oct 29, 2012 | 11:29 AM
jkeaton's Avatar
I think I paid like $125 for mine off ebay (used), then another $40 for the OBD1 cable from amazon. It was worth every cent for me.
skinut
Dec 12, 2010 12:52 AM
White94Z28
Mar 13, 2010 07:32 PM
libertyforall1776
Mar 27, 2009 02:37 PM
94z
Dec 5, 2008 01:21 AM
DaveyM
Jun 15, 2008 10:55 AM
