cooling fans wont work
RE: cooling fans wont work
I had the same problem. Here's what I did: changed the radiator (found a leak), changed the radiator cap, had to bleed coolant lines, installed a manual fan switch. I recently removed the a/c system and everything still works great. Hope this helps.
