cooling fan
hi everyone. i'm back with another problem.i have a 95 camaro 3.4. my cooling fan quit working. i've changed the relay and still nothing. after further investigation, i realized i'm getting no power at the plug. i have power in fuse box and have replaced the relay and still no power at the plug. i'm assuming something is wrong between coming out of fuse box to the plug. something in that wire. do you think my assumtion is correct. should i pull the fuse box and track that wire to the plug. what everyone think. thanks in advance.
get on youtube and do a search for using volt meter. also there is a fuseable link in the fan wiring that could be bad. looks like a lump in the wire. test for power on both sides of lump
thank you for the drawnings. i've been using them. peterpar, i'm saying i have no power at the plug. ok so this is where i'm at,i'm following chart c12 page 2.i'm on step 2. i've located ckt335. but don't know where b+ is or understand how to hook test light. i also read jumping across d1 and d4 should energize the fan. i did that and the fan came on. anyone know where this b+ is and how to hook test light uo. thanks....
