Coolant question
Old Sep 22, 2012 | 06:28 PM
nickb123's Avatar
Default Coolant question
As we all know winter is coming up soon and if you live in a state like Minnesota you might be thinking about storing your car, like me. One thing i know to check is the freeze protection for the coolant. I just checked mine and its good for about positive 5 degrees Fahrenheit. but it gets much colder here so I need to do something about that so I have some questions. 1. how should I drain? It has green coolant so that is what ill be using and it looks clean. So should I just drain the radiator and refill it with new stuff? I don't know if that will keep the block from freezing or not (BTW, its a 1998 LS1). and if I drain the radiator should I use the drain valve or disconnect the lower hose? what gets more out? That's about everything for now, so thanks for the responses in advance.
Old Sep 23, 2012 | 12:18 PM
|m()d's Avatar
this should answer everything for you 4th Gen LT1 F-body Tech Articles
Old Sep 23, 2012 | 10:25 PM
MKCoconuts's Avatar
Shoebox is a good website. If you really wanna get through with it, drain coolant from the drain **** on the radiator, pull all the hoses, pull the knock sensor and the temp sensor on the head, that should get most if not all out.
Old Sep 24, 2012 | 09:15 PM
Greg08's Avatar
WOuld it be better for him to do a cOmPletely drain it or add lots of antifreeze ?
Old Sep 24, 2012 | 09:51 PM
MKCoconuts's Avatar
Personally, I'd drain as much as I can out. It's not going to hurt anything and new antifreeze/coolant isn't a bad thing either. If a little bit stays in it's not a big deal. The new stuff will dilute the old.
Old Sep 25, 2012 | 07:55 AM
jkeaton's Avatar
I'm driving mine year round! Except if it snows, of course.
Camaroboi22
Feb 3, 2013 09:56 AM
sbryan
Oct 21, 2011 12:05 AM
Motor60
Mar 16, 2011 11:47 AM
chewybacca11
Aug 29, 2010 03:56 PM
92Camero
82-92 V8 Tech
Jun 10, 2007 08:44 PM
