Coolant in motor
Old Feb 16, 2014 | 12:58 AM
Derek Tackett's Avatar
Default Coolant in motor
is it possible to have some leftover coolant in motor after headgasket change
Old Feb 16, 2014 | 05:34 AM
yes, you should change the oil after doing the gasket job. there is usually a very small amount of coolant left after a gasket change and oil change but it should evaporate with first run to operating temp. if you have doubts and its possible that coolant is still leaking then better get the coolant system pressure tester out and test it.
Old Feb 16, 2014 | 10:36 AM
You must change oil after a head gasket replacement. DO NOT drive a car with coolant in the oil, it will cost you a motor.
Greg08
Oct 4, 2012 09:31 AM
threevolve
Aug 21, 2012 12:18 PM
Camaro3800V6
Aug 17, 2011 03:47 PM
AnalyzeFaith
Dec 5, 2010 05:54 PM
95camz28
Dec 16, 2007 07:40 PM
