coolant level
Old 10-27-2012 | 07:35 PM
Dana's Avatar
It is that but the end that goes into oveflow isn't a hose. It's metal.
Old 10-27-2012 | 08:00 PM
MKCoconuts's Avatar
Should be able to remove the hose from the metal piece if I remember correctly. I'll have to look tomorrow, all ready pulled the car of the garage for the night.
Old 10-27-2012 | 08:07 PM
Dana's Avatar
It looks like 1 piece but wouldn't matter. The hose part is fine, the metal post bent in half at the crack it had and broke into.
Old 10-28-2012 | 07:55 AM
Old 10-28-2012 | 09:07 AM
torque_is_good's Avatar
as was explained, it's more of an expansion tank than overflow because coolant is also supposed to revert back to the radiator. It is bi-directional
But, if you are troubleshooting 4 ounces or more of coolant loss from the radiator then you are barking up the wrong tree thinking it's the expansion tank (it's referred to as overflow but it does more)
if it's more than 4 ounces then you need to find where the coolant is going
Old 10-28-2012 | 04:58 PM
Dana's Avatar
Originally Posted by craby
It's page 234 #15 and called HOSE COOL RCVY RSVR but I can't find that on any websites I've been on. I've even tried some GM sites. I wonder if it's even replaceable?
Old 10-28-2012 | 04:59 PM
Dana's Avatar
I get that. It's not THAT much coolant that is going down but regardless, this part has to be replaced.
Old 10-28-2012 | 11:02 PM
the metal hose is no longer available. new rubber hose and try metal pipe with elbows on each end.
Old 10-29-2012 | 08:52 AM
awesome. I gleaned from the post that it was a more severe problem
Chrisd0729
09-04-2011 11:07 AM
evilbeef54
07-27-2008 10:47 PM
aleksandr
03-25-2008 02:50 PM
stud1502
10-19-2007 02:19 AM
user 7208220
08-29-2006 08:07 PM
