Cleaning Intake
Old Jan 1, 2009 | 04:30 PM
sschic's Avatar
Default Cleaning Intake
Halfway through swapping the plugs and wires....[:@]. Took off the throttle body while letting my arms heal! Noticed it and the intake have a lot of carbon buildup. Cleaning the TB by hand, but is there a good way to clean the intake WITHOUT taking it off. I used to see some spray stuff you could shoot into the TB while running and it would clean pretty good. Kinda hard to pour in seafoam at 90 degrees. Planned on running a couple tanks of cleaner in the gas, a cleaner on the next oil change and something in the intake...suggestions?
Old Jan 1, 2009 | 08:54 PM
JD1969's Avatar
Default RE: Cleaning Intake
It really will not help and will look dirty in a few days again. This is due to the PVC system letting a tiny bit of oil vapor intot he intake. BTW if you remove the coil packs and the EGR tubes changing the plugs is much easier. HINT: leave off all but two coil pack bolts on each side when you re-install them, that way they come off in seconds next time.
Old Jan 1, 2009 | 09:05 PM
94CamaroSFI's Avatar
Seafoam Deep Creep Should work
Old Jan 3, 2009 | 09:07 PM
sschic's Avatar
Thanks! Busted a wire on the last plug...waiting for the new set to come in from Summitt. I'm hoping the slight miss I was hearing was from the plug wire that broke, cause I didn't pull hard at all and it snapped easy!!
Sicilian
Apr 24, 2013 07:02 PM
Raven93
Jun 14, 2012 10:10 AM
x01660
Jul 17, 2011 11:46 AM
WIspartan1026
Jul 19, 2009 07:43 AM
350rs
Mar 5, 2007 12:38 PM
