Chevy 383 Question
Old Apr 5, 2009 | 08:40 PM
ledzeprokon6's Avatar
Default Chevy 383 Question
I was going to buy 383 motor on criaglist. I have a 97 camaro rs V6. I live in Massachusetts if i was to put this motor in would it pass inspection?
thanks
Old Apr 5, 2009 | 11:28 PM
greenarrow's Avatar
September 2009 ROTM
You can make it pass inspection, but it may cost you an arm and a leg to get it there. You'll have to give us more details on the engine. cam/heads/carb-FI, that stuff, or just post up the link.
Old Apr 6, 2009 | 01:07 AM
95slvrZ28's Avatar
You also need to make sure that you are capable of finding the parts etc. that need to go into the swap.
Old Apr 6, 2009 | 01:06 PM
http://boston.craigslist.org/gbs/pts/1105917420.html
that is the ad. I talked with the guy and he said it will bolt right in to my car.
Old Apr 6, 2009 | 03:20 PM
95slvrZ28's Avatar
It will not bolt right into your car. In the very least you're going to need a V8 K member (or tubular K member) and you'll have to work with the clearance with the cowl and the distributor. The 4th gen cars with the V8 in have the distributor mounted on the front of the motor with a different front cover etc. It's not just a "bolt in" and call it good sort of job, it's quite involved.
Old Apr 6, 2009 | 03:30 PM
Well i am not worried about the work it would take. i have plenty of time on my hands. I am just worried about money it would take to make it work and pass inspection. Inspection is the most important for me
Old Apr 6, 2009 | 09:19 PM
lt4weeda's Avatar
The engine itself should matter on your inspection. The emissions is a whole nother story, but if I was going to the extent of putting a 383 in one of my vehicles the last thing I would be worried about would be if it would pass emissions.
truckgirl80
82-92 V8 Tech
Aug 14, 2011 10:59 PM
Jville_hot_skate
Feb 18, 2009 11:26 PM
JGaeta03
Feb 18, 2007 02:22 AM
rpdalton
Apr 12, 2006 03:45 PM
