Change check engine light help!!!
Old Dec 11, 2017 | 10:29 PM
Robert Jelinski's Avatar
Default Change check engine light help!!!
Long story short owned 2000 Camaro for over 2 years *** hole before me just broke the check engine light bulb instead of fixing the car the car has been fixed for some time now but I changed all my bulbs to leds today and I didn’t know the check engine light is connected to the printed circuit board is there any way to fix these bulbs pulled whole cluster gauge from junk yard but that has bulbs out on it as well so looking to fix my cluster any advice thank yo
Old Dec 12, 2017 | 09:33 AM
can you post up some pictures.
Old Dec 12, 2017 | 10:47 AM
As soon as I get home tonight I’ll take a picture of It around 6 est tonight thank you.
Old Dec 12, 2017 | 05:27 PM
Old Dec 12, 2017 | 05:28 PM
Those are the check engine light and the security bulb there sodered into the board itself
Old Dec 12, 2017 | 05:49 PM
Everett#2390's Avatar
They are LEDS.
Use 25 watt or less soldering iron and get the positive lead into of diode into the correct hole.
DO NOT use radiator solder, use 63/37 tin/lead solder rosin core.
Radiator solder will make for a cold solder joint and lights won't work and you might as well get a new board as it will be impossible to remove.
Old Dec 12, 2017 | 06:05 PM
Ok thanks how do I know what one is positive and where do I get bulb like that
Old Dec 13, 2017 | 09:10 AM
Before doing anything, place/mark a dot on the top of the light so it goes back in correctly.
You might try a cluster repair shop, if not another board from another car.
AmericanMuscle1989
Jun 25, 2013 10:38 AM
Chevykicksbut
Oct 28, 2009 07:14 AM
