Car heating up while running AC
Old 08-01-2007, 08:48 PM
Chappie99's Avatar
Default RE: Car heating up while running AC
Come on people... Pete said make sure the thermostat is in place so that the coolant isnt runing throught to fast... Lets make it easier.. MAKE SURE YOU HAVE A THERMOSTAT IN PLACE UNDER THE THERMOSTAT HOUSING....People take them out so that their engine runs cooler.
Old 08-01-2007, 09:39 PM
usarmyrangrs's Avatar
Right, but the only flaw in that logic with a completely computer controlled vehicle is that it would REALLY struggle to reach closed loop status, causing a slump in fuel ecomony and causing a new array of problems. Even if the guy checks and has no thermostat, he's experiencing overheating problems, not overcooling. With the A/C on, you have a great amount of heat being dissapated by the condenser. The higher the heat, the higher the pressure and vice versa. I think this may be a simple fix, whether it may be a sticky thermostat, a worn radiator cap, or a partial cooling system fill. Always start with the easiest solutions.
mrsdeano
09-23-2010 10:35 AM
orlando_trudeau@yahoo.com
06-16-2009 12:35 PM
2fast4u
04-22-2008 06:55 AM
GoofieJ21
09-24-2007 07:32 PM
coolcat
06-28-2006 04:57 AM
Quick Reply: Car heating up while running AC
