STILL HEATING UP!!!!!!
Old May 10, 2006 | 01:44 AM
coolcat's Avatar
Default STILL HEATING UP!!!!!!
My 89' RS 2.8L heats up for Everything, i'm running a 180 Thermostat(working), put a new radiator(working), flushed the engine, changed the cap, it has enough coolant, and the water pump is working cause i let the top radiator hose open and when the thermo opened all the coolant came out(don't worry it's back on) HELP ME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11[:@]
Old May 10, 2006 | 09:12 AM
blackz87's Avatar
Default RE: STILL HEATING UP!!!!!!
AIR DAM,,,,,,,
Old May 10, 2006 | 02:07 PM
coolcat's Avatar
what would the air dam have to do with it???
Old May 10, 2006 | 03:58 PM
blackz87's Avatar
The purpose of the air dam under the car is to push air up to the radiator thus cooling it and making the car run at a lower temperature.
Also do you have one on the car??????
Old May 10, 2006 | 06:13 PM
SickSickSick's Avatar
You May Have To Face The Reality Of A Cracked Head Gasket. Sick
Old May 10, 2006 | 08:52 PM
coolcat's Avatar
if i had a cracked head gasket wouldn't the coolant seep into my oil???
Old May 10, 2006 | 09:44 PM
Not Nessarily. It Depends On What Location Of The Gasket The Crack Is In. Check Your Spark Plug Tips For White Buildup. Sick
Old May 10, 2006 | 10:20 PM
coolcat's Avatar
you think the heater core might have something to do with my problem?? So how did the drags go the past weekend?????
Old May 10, 2006 | 11:33 PM
Usually The Only Thing A Heater Core Will Have To Do With Overheating Is If It Is Leaking. It Would Be Obvious By A Wet Floor Board. Drags Was Alot Better Than The First Time. Still Got Some Work To Do On it. I Posted The Outcome And A Video Under Street/Strip " Sick's Misadventures " And The Time Under Timeslips. Check it Out At Your Leisure. Sick
Old May 11, 2006 | 02:53 PM
IMAREALBOYNOW's Avatar
if it's a elec. fan make sure that thing is turning on when it should my 92 and my buddys 86 camaro had the same problem we just wired it to a switch and turned it on when the car started to get hot i know this seems to be a problem in the 3rd gen camaros so just check that if you didnt already do so
